1991 accord sometimes take awhile to start
Old Apr 15, 2009 | 06:54 PM
doubled's Avatar
Default 1991 accord sometimes take awhile to start
Sometimes it starts right up, others, I need to keep cranking. I always wait about 3 secs to allow the fuel pump to pressurise the systm. Could it possibly be the fuel filter? 200k mi and I dont know if its ever been changed. How mush is a pressure tester?. Or is it just cheaper to replace it anyways?
Old Apr 15, 2009 | 07:05 PM
I very much doubt it's the fuel filter, however the fuel filter is easy to access and replace. You will need a restraint wrench (19mm I think) to hold the fuel filter cannister while you break the tubing nut at the top. Use a flare tubing wrench to avoid rounding the tubing nut. I found the tubing nut to be very tight.
Hard starting can be due to weak spark plugs, wires, distributor cap, or rotor. Make sure all these items are good.
Clean or replace air filter.
djfalcon
Mar 1, 2015 12:28 PM
jmalek
Nov 7, 2011 11:24 AM
19Accord91EXlady
Sep 23, 2008 09:16 PM
cuatro201821
Apr 1, 2008 09:06 AM
coupe_hybrid
May 31, 2006 10:11 PM
