94 ex idling high after driving awhile
Old May 31, 2006 | 06:35 AM
coupe_hybrid
Default 94 ex idling high after driving awhile
My car is a 1994 ex accord 5spd manual. Lately I've been noticing that after driving my car for awhile when I go into neutral my car idles super high at like 2k rpms and stays that way until the engine is cool again. When I first start the car and drive it, it idles perfectly at 700 rpms. I'm worried that this is gonna be affecting fuel economy on my car.
Old May 31, 2006 | 04:23 PM
sir_nasty's Avatar
Default RE: 94 ex idling high after driving awhile
just to clarify it idles at that point even when nothing is running besides the motor? I.E. no a/c on
Old May 31, 2006 | 04:25 PM
sir_nasty's Avatar
side note: I have seen/heard of this occuring due to the car needing a tune up... I.E. Plugs wires, cap, rotor (if applicable) and air filter (I've seen it where a plugged air filter causes a higher idle... but that was on an older chevy I believe...
Old May 31, 2006 | 04:50 PM
YeuEmMaiMai's Avatar
check your ICV. usually when the car heats up something may be binding or a value has changed for the resistor. also check your TB for freedom of movement when engine is at operating temp.
Old May 31, 2006 | 08:03 PM
coupe_hybrid
Thanks for replies I'll check on those things and get back to you guys!
Old May 31, 2006 | 10:11 PM
deserthonda's Avatar
Also aside all the good ideas that were adviced to you,, remove the intake tube from the throttle body and clean the trottle plate,, i have seen them gum up and stick .. get some carb cleaner and a rag, spray cleaner on rag , open the plate by the accell cable and clean all the area where the plate would open and close ..
djfalcon
Mar 1, 2015 12:28 PM
94_Accord
Jul 30, 2013 09:49 PM
KD1977
Jan 6, 2012 12:58 PM
doubled
Apr 15, 2009 07:05 PM
19Accord91EXlady
Sep 23, 2008 09:16 PM
