1991 Accord Wagon electrical issues
Old Jun 28, 2025 | 09:48 PM
ErrandWolfe's Avatar
Default 1991 Accord Wagon electrical issues
Had my car die on me today and had to get it towed home. Turns over, but appears to not have spark, won't run. Power windows, sunroof, blower, instrument panel lights, and turn signals don't work. I noticed the other day that my dash dimmed a tiny bit when my turn signal was on. Any suggestions for fusable links or relays to check. Thanks.
Old Jun 29, 2025 | 04:45 PM
Any recent work done on the car or other issues other than the dimming?
The dimming and the no spark might not be related, so I'd treat them as separate issues and figure out the no spark to get the car running. This won't be a fuse problem as a fuse is typically working or blown.
The coil should have a blk/yel or yel/blk wire that gets 12V from the ignition switch. You shoudl check that you are getting 12V to the coil with a volt meter.
You can also inspect the distributor cap and rotor just to make sure they aren't severly worn out and making poor contact.
Old Jun 29, 2025 | 04:49 PM
It was the ignition switch/harness. The run position was shot. Acc and start were fine. Fixed it today. 267k and still going strong.
Old Jun 29, 2025 | 05:24 PM
The ignition switch is not uncommon especially after 30 years if it was the original. Glad you figured it out and thanks for posting the solution.
beastyme
Oct 17, 2012 06:40 PM
Pajamarama
Jun 8, 2012 08:57 AM
Drake75
Mar 24, 2012 12:34 PM
JollyGreenMini
Sep 18, 2010 09:29 PM
bgriffin09
Aug 22, 2010 01:55 PM
