Sponsored by:
Sponsored by:
1991 dx with dash lights and parking light problem
  #21
Old 04-20-2012, 09:42 AM
NY_Pito_NY's Avatar
small lights fuse is fine...not blown
  #22
Old 04-20-2012, 09:45 AM
NY_Pito_NY's Avatar
your right about my situation...the dimmer switch is not the problem
  #23
Old 04-21-2012, 10:04 PM
NY_Pito_NY's Avatar
ok i checked the dimmer according to the thumb nail you posted...its all good...
  #24
Old 04-21-2012, 10:08 PM
NY_Pito_NY's Avatar
My problem was no front corner, tail, or dash lights including a/c & gear selector, but power to cluster enough to tell me what position the transmission is in. If its not for the flashing S and the D for drive the cluster would have no indication of light at all.
  #25
Old 04-21-2012, 10:26 PM
In the under hood fuse box, there is a dimmer relay. See if you can switch with an identical relay.
I don't have a good wiring diagram of the 90-93 accords, so this may be difficult.
Do you have a volt meter?
Can you tell us the color of the wires going to your tail lights?
  #26
Old 04-22-2012, 07:43 AM
So the Black had good ground under all conditions.
The Red/Black had 12v when the light switch is on.
You ground the Red wire (with the lights on) and the dash lights went "full bright".
Is this true?
  #27
Old 04-22-2012, 07:57 AM
crispin's Avatar
Is this true?
I was wondering the same thing because if that was true he would not say that he still does not have cluster lights.
  #28
Old 04-22-2012, 11:38 AM
NY_Pito_NY's Avatar
ok this is what i got ...Neg is true. Red black has nothing..even when the lights are on, it made no difference.
  #29
Old 04-22-2012, 12:12 PM
Now we are getting somewhere.
No power to the red/black, time to work our way back up the system and find out why.....still not sure why you said it tested fine? Anyway.....
All fuses are good, including the under hood fuse panel (#19, #27 and #41).....correct?
If so, time to test the light switch.
I'm really trying to help. If you want it, if not I can move on?
  #30
Old 04-22-2012, 12:23 PM
NY_Pito_NY's Avatar
do you have a thumb nail of the U/H fuses numbered..Your doing great..i appreciate your help..i think with your help we can get the bottom of this..i was using a fault voly meter...I used a stardard light tester. I used it to test the hazard lights switch ....that switch has power when activated...it blinked on and off to the rythm of the light flow.
Quick Reply: 1991 dx with dash lights and parking light problem
