1991 honda accord ex will not engage out of park
Old Nov 18, 2010 | 03:31 PM
thadjons2007's Avatar
oh and i just wanted to mention that when i replugged the TCU back in and turned the car on i heard a series of clicking sound coming from the shifter area and when i put my hand on the shift i could feel that the sound was coming from there.
Old Nov 18, 2010 | 03:56 PM
Right now you are guessing what the problem is. There is no need to replace a working part.
Grab a piece of wire or a thin paperclip, find the blue two-pin connector. Short it. Turn the key to the II position, then count the S light flashes. It is really simple to do.
g22cd5's Avatar
Supper Moderator
it's a solenoid that locks into park. It most likely went bad. Happen to mine I just removed it. But if you remove it you won’t have to press the break to get out of park also when the car is off you can shift out of park. You just have to remember that if you do remove it.
Old Nov 18, 2010 | 04:26 PM
ok i will try to do this PAhonda, i hear the blue pins are behind the little kick panel on the right side of the passenger side? i will try this tonight after dinner and see what happens
Old Nov 18, 2010 | 04:34 PM
Here is the DIY writeup with links.
https://www.hondaaccordforum.com/for...ad.php?t=35962
Old Nov 18, 2010 | 05:01 PM
either im a idiot or just a idiot...so i found the opened blue connector stuck a paperclip into the slots to bridge it and turned the key to the number two position and nothing. Should i atleast wait for 10 minutes or less the sport light was just solid unless im not doing a good job shorting this thing out or the paperclip is too thick.
Old Nov 18, 2010 | 05:12 PM
  #17
You may want to use a flashlight to look at the connector. There appears to be four holes on the connector, but only two have pins. Short the holes with the pins. See pic below. The location is different, because this pic is for the 94/95 accord. The connector is the same.
If you turn the key to the II position, the CEL should turn on and stay on if there are no codes. Or it will flash when you turn on the key. If it doesn't, then you didn't short the connector.
The S light should start flashing within a few seconds of turning the key to the II position.
Old Nov 18, 2010 | 05:51 PM
  #18
ok so i guess i shorted it all the lights stay on but the sport mode light stays solid. ive waited for it to blink for about 3 minutes and nothing and the CEL lights just stays solid also
Old Nov 18, 2010 | 07:14 PM
  #19
It sounds like you have a TCU problem. If you are good with a soldering iron, you can try to replace the bad resistors and capacitors.
Your problems sound very similar to the symptoms on this site for the TCU:
techauto.awardspace.com/transmission.html#troubleshooting
I would inspect the resistors that are pictured.
If you don't want to solder, you would probably want to get a used TCU from a junkyard.
Old Nov 18, 2010 | 07:28 PM
  #20
unfornately i still need to drive the car to get back and forth to work, do you think its safe for atleast a week with totally damaging the tranny. Until my new TCU comes in
