1991 honda sputtering
Old Nov 26, 2007 | 12:40 AM
artemiohonda
Default 1991 honda sputtering
I recently gassed up my 1991 Honda Accord and when I was leaving the gas station the engine began to sputter like it was getting enough gas. I changed the fuel filter and put some gas treatment in the tank but it is not helping. The car only has 130,000 miles and I hopeit is nothing major. Any suggestions much appreciated.
Old Nov 26, 2007 | 05:58 AM
Default RE: 1991 honda sputtering
Place your car description in your signature line.
Need more history of maintenance. Any spark plug, spark plug leads, rotor, distributor cap changes? Timing belts changed at ~ 90K miles?
Air filter and all vacuum lines should be checked. Check spark plug wells for oil which can short out plugs (leaking seals). Check PCV valve and hose for cracks, clean PCV, blockages in hose. Clean throttle body plate and bore (as far as you can reach w/ throttle body cleaner. Clean idle air control valve (IACV) w/ throttle body cleaner.
Old Dec 1, 2007 | 11:15 AM
HondatechAV6's Avatar
bad gas? coincidence it JUST happened after filling up? didn't put e85 in or diesel...anything?
crashdummie
Aug 14, 2013 07:35 AM
Metrex1992
Jun 7, 2013 01:28 AM
Bleedinpurp
Mar 31, 2013 03:17 PM
CB7-SE-1991
Jan 29, 2013 04:45 PM
zomburs
Jul 7, 2011 12:03 PM
