1991 transmission problem code 7
Old May 10, 2009 | 06:04 PM
moto310
Default 1991 transmission problem code 7
The sport light flashes as soon as I shift into drive. The code I retrieved was seven(solenoid A lock up). I removed solenoid, cleaned it, and tested it. I put it back on, cleared the code. And I still have the same problem. Do I need to get a new solenoid or TCM or other? Any suggestion will be appreciated.
Thank you.
Old May 11, 2009 | 03:36 PM
hondadude's Avatar
Test the solenoid, it has one power lead and the base is ground.
When you energize it you should hear a STRONG CLICK.
Old May 11, 2009 | 09:33 PM
moto310
I energized both solenoids and they click strong.
mishakol129
Mar 17, 2013 09:17 AM
CB7-SE-1991
Jan 29, 2013 04:45 PM
scasper
Oct 5, 2008 10:10 PM
postred
Jul 11, 2007 12:35 PM
GolfmanSpeck
Nov 16, 2006 01:36 PM
