1992 accord every shop in town stumped
Old Jul 3, 2010 | 04:23 PM
terex4400's Avatar
Default 1992 accord every shop in town stumped
I need help. I have a 1992 honda that has a jummpy tach, stalls out when excelerating but runs fine when you back off the gas. If you floor it it over fules and back fires. I have already done some things here is a list.
1.changed coil twice
2.changed dizzy twice
3.changed main relay
4.changed ecm
5.replaced grounds
6.removed pluged cat
I'm planing on changing the tps and testing the charcoal canister next.
I need some new info I'm getting stumped.
Old Jul 3, 2010 | 07:29 PM
Does the check engine light or the S or D4 light start flashing when driving?
Have you checked for any code(s) stored in the ECU or TCU? Get a piece of wire or a thin paperclip to short a blue two-pin connector.
Copy and paste this into your web browser to see the procedure to get the codes: techauto.awardspace.com/dtc.html
Old Jul 3, 2010 | 08:08 PM
terex4400's Avatar
RE 1992 honda .no check engine light and the car is a standard. there is no codes as well.
Old Jul 3, 2010 | 10:07 PM
deserthonda's Avatar
chk fuel pressure . also chk the gas itself, pour some gas in a container make sure that it is not contaminated cam timing ok?
Old Jul 4, 2010 | 12:01 AM
Did you change the spark plugs? New distributor cap and rotor? Spark plug wires (I like NGKs or the honda ones)?
Old Jul 4, 2010 | 12:38 AM
terex4400's Avatar
New plugs,wires,and two new distributers. I have looked up and tested for every problem befor replacing parts.I'm going to doubble check the timing and replace the tps. I took out the charcoal canister it helped a bit.
Old Jul 4, 2010 | 12:45 AM
g22cd5's Avatar
Supper Moderator
you said you switched the ECM for the tranny right?.... the tranny and ECM are matted 2geather from the factory. That COULD be why..Iv seen it happen when you swap around ECM's
Old Jul 4, 2010 | 11:45 AM
terex4400's Avatar
The trany is a standard dose that still matter. It still does it with the ECM that came with the car. The guy I bought the car from did the work he did an engine swap. 11/1990 engine into a 1992. The tach is moving with the throtle now and the car is sputtring like the timing belt is out a tooth or two.
Old Jul 4, 2010 | 12:14 PM
g22cd5's Avatar
Supper Moderator
do you mean ECU? cus I was thinking TCU the tranny computer. But since your 5speed you dont have a TCU in your car just the ECU.
Old Jul 4, 2010 | 04:22 PM
terex4400's Avatar
I think I wone the timing belt pullys all line up but the timing balencer is out one tooth. i hope this will fix the problem.
1LordAccord1
Jun 19, 2012 08:33 PM
autobot_78
Sep 27, 2010 06:48 PM
steventokc
Dec 15, 2009 04:58 PM
ALKENDI
Sep 26, 2008 11:56 AM
gvox
May 9, 2007 12:33 PM
