1992 accord manual trasmission issues
Old Jul 13, 2011 | 12:18 PM
DOEceeDOE's Avatar
Unhappy 1992 accord manual trasmission issues
ok so the clutch will only let me change gears when the car is off.when its on i can only put it into gear manually by forcing it past the grind..ouch...anyways just replaced the slave cylinder where you put fluid.when you in gauge the clutch u can see the arm move a little bit under the hood that's changing the gear but it still ain't working correctly ?????what the *****....any ideas oh and where the metal line goes in to tranny looks like its either broken underneath rubber slave but not sure if its just the rubber that gives that illusion because of how the tube bends i dunno im not a mechanic and i think i ****** up letting the tweaks down the street work on it .it don't seem to be leaking fluid anywhere.so im thinking its got a pressure leak somewhere that's not allowing the fluid to the hydraulic ...anyways help....
Old Jul 13, 2011 | 04:33 PM
piggylover1985's Avatar
Did you bleed it after changing the slave cylinder ?
Old Jul 13, 2011 | 04:43 PM
Tek310's Avatar
sounds like binded clutch cable.
now you say it wont let you shift when the car is on? when you press the clutch pedal does it disengage the clutch disc? say your stopped is there chatter? pulling like the car wants to continue forward?
how long has it been since you replpaced the clutch and pressure plate?
how does the clutch pedal feel? spongy or firm?
with it not letting you switch gears when the engine is running makes me think, the clutch is not disengaged completely or your pilot bearing may be seizing up and keeping the input shaft in motion when pressing in the clutch.
it could also be a bent clutch fork or like i said before kink in the clutch cable
flyingfinn73
Jan 31, 2010 02:39 PM
cumminsman
Feb 13, 2008 12:09 PM
92accordman
Aug 9, 2007 11:29 AM
tony11
May 29, 2007 08:00 PM
