1992 accord transmission codes
Old Jul 25, 2012 | 09:21 AM
darode1's Avatar
Default 1992 accord transmission codes
I have a 1992 accord wagon. it has a tramission problem. D4 on constantly. won't shift right. i have several advices on possible causes. all indicate i need to retrieve the trans codes but i have not an explanation on how to do that. i assume there is someplace it needs to be jumpered but don't where that is. anyone can help and explain how to retrieve those codes? thanks,, darode1
Old Jul 25, 2012 | 11:44 AM
Check DIY forum for instructions on extracting OBD1 flash codes. Trans codes are same procedure except D4 light will flash rather than Check Engine Light.
Post your code/s for help.
Old Aug 17, 2012 | 03:12 PM
darode1's Avatar
Default finally back again with update
between my 10 year old having her appendix out and then 4 days later developing kidney stones that have not yet passed and will need to be lasered, there has not been much time to get working on my accord. good news is the shifting problem has been resolved solely by cleaning the 1st/2nd solenoid. must have been a little dirt in the passage. works fine now. check engine code is 12 which i believe is exhaust gas recirculation. i have no idea what i need to do fix that. any ideas? i will check the DIY section. maybe there is something there. thnaks for any advice. david
Old Aug 17, 2012 | 06:29 PM
There is an extensive diagnostic procedure to determine whether vacuum supply to actuate valve is missing, valve is stuck open/closed, or possible blockage of EG passages. If you want to DIY, suggest downloading a 90-93 Accord manual to get the diagnostic procedure. See Online Manuals post links in DIY forum.
If EGR passages have never been cleaned, this may be the problem. Howeve, EGR system is complex and can have faults at several locations.
Old Aug 18, 2012 | 01:45 PM
darode1's Avatar
Default huge downside if fixed promtly?
is there a huge downside if this problem is not promptly fixed and i just live with the light on? i don't have a vacuum tester nor a vacuum maker at my immediate disposal. the light did not go on right away after i reset the system by disconnect the neg battery terminal. only came on after the car was up to temperature. i assume it stays in one mode until temp is reached then tries to open a valve and at that point determines something amiss with a parameter at that setting and throws the code? i will try the easy stuff first, cleaning passages, examining the valve as best i can and then see if that does any good before i chase down some other equipment. maybe autozone or oriellys has those tools in their lending library. thnaks, david
1992 accord wagon
1992 accord coupe
1986 nissan d21 truck that just keeps going and going and going.......
1995 saturn sl2
1969 datsun 1300 pickup truck that i hope to put a bigger engine in
numerous motorcycles
Old Aug 18, 2012 | 02:31 PM
The EGR is enabled when the engine gets to operating temperature.
I would follow the vacuum hoses from the EGR valve to the two EGR controls (solenoid and vacuum control valve). Make sure the vacuum hose hasn't rotted where you would get a vacuum leak.
Old Aug 22, 2012 | 12:23 PM
tulsaHONDA's Avatar
anyone know of an immediate repair for hard shift , 1st to second ?? please email me, thanks
Old Aug 22, 2012 | 05:33 PM
So Tulsa... what kind of car are YOU talking about? Should we guess?
quint2
Aug 21, 2017 08:28 PM
jrod81
Jun 29, 2014 08:05 AM
voteforpedro
Oct 28, 2009 11:53 AM
voteforpedro
Oct 6, 2009 02:54 AM
larrysnach
Mar 11, 2006 10:48 PM
