2005 Accord AC quit suddenly. Blows hot.
Old Aug 22, 2012 | 11:39 AM
Cramer05's Avatar
Default 2005 Accord AC quit suddenly. Blows hot.
It appears that AC problems are fairly common on this forum, but a search didn't produce what I'm looking for.
This is on my girlfriend's car, so I don't know exactly what happened. She was driving home and I guess the AC started to make a funny sound, so she turned it off. Drove a little bit and switched it back on, but now it only blows hot air. The compressor clutch is not engaging when the AC is on. I haven't checked the freon yet. I didn't think that would be the issue since it quit so suddenly. I've been thinking maybe a low pressure switch?
Old Aug 22, 2012 | 12:27 PM
First, make a visual inspection of the AC condenser to see if a rock or debris punctured it.
Old Aug 22, 2012 | 07:26 PM
You cnn jumper the hi/lo pressure cut-off switch and see if compressor comes on. Stop AC immediately if it engages (cut off AC master switch).
If compressor engages w/ this test, the system pressure is low disabling AC, then a leak is likely.
If compressor still will not run, the an electrical problem is very likely. Possible faults are compressor clutch gap too large, faulty AC compressor relay, damaged wiring.
Tony1M
Nov 6, 2023 08:29 PM
emerald
May 25, 2020 05:14 PM
4x4aholic
Nov 3, 2013 06:26 AM
Tashwinder Cheema
Sep 4, 2013 08:56 AM
jd21476
May 9, 2007 03:47 PM
