1992 Honda Accord fans while engine off
Old Jun 10, 2012 | 09:28 PM
acesn8s's Avatar
Default 1992 Honda Accord fans while engine off
This may sound silly, but how many fans run during cool down with the engine off. I never opened the hood to look. I ask because I had to remove the driver side fan while replacing the O2 sensor. Today I had to open the hood with the fans running and only the passenger side fan was running. Is that just to preserve battery juice with the engine off? The engine never gets hot while running. Thanks in advance!
Old Jun 10, 2012 | 09:39 PM
The passenger side fan is the radiator fan. So, it is normal if that is the only fan running after it is off. It is to cool the engine if after shut off, if the coolant temp. reach approximate 217 - 228 degrees F at Thermoswitch B.
The driver side fan is the AC condenser fan.
Old Jun 11, 2012 | 10:19 AM
You can check the fans by turning on the A/C. Both fans should run.
Or...
Follow the LOWER radiator hose back to the thermostat housing (below the throttlebody). In the T-stat housing is a switch with a 2-wire plug. Remove the plug & jumper between the 2 wires with a paperclip or piece of wire. Key ON, that should make both fans run.
Old Jun 23, 2012 | 06:46 PM
acesn8s's Avatar
Thanks guys. I guess my driverside fan won't get a workout, my A/C quit years ago. I appreciate the help!
Old Jun 24, 2012 | 06:46 AM
BOTH fans should run when you do the test Jim outlined.
When the car is running and thermo a (t-stat housing switch) reaches ~194, BOTH fans come on.
Jenny Jordan
Dec 22, 2023 11:04 AM
heronbassett
Aug 14, 2014 10:14 PM
eld5k1
Oct 28, 2012 08:09 PM
POS-Accord92
Jan 5, 2012 11:14 PM
1stchild
Sep 14, 2007 04:15 PM
