1992 Honda Accord No Crank Draw Test
Old Sep 26, 2012 | 12:07 PM
miraha's Avatar
Would the battery issue be resolved by a jump off from a truck with good battery?
Old Sep 26, 2012 | 12:59 PM
miraha's Avatar
Fresh recheck 1:30 pm today showed Battery checking at 12.55v
Between battery and starter motor pos. connection checks the same, 12.55
Battery - to solenoid B&W starting checks at rest 0, at start 11.44
Jumped with Ram 1500 new battery which was checking 12.6, 13.6 while running.
While jumping, car battery checked the same 13.6
While jumping, car battery neg to starter pos., at rest, checked same 13.6
While jumping, car battery neg to solenoid B&W checked 0 at rest, 11.37 at start
Am I right to think this would cancel out the battery being the issue? in that the jumpstart readings at battery and starter pos make battery a moot point?
The continuity check per Helms on S terminal (B&W wire) and M terminal (starter pos cable connection post) shows no continuity; my thinking is that this points to a solenoid problem causing the open (worn contacts)?
Also, reads 12.2v from starter casing to starter pos connect - suggesting solenoid failure
Thanks
Old Sep 26, 2012 | 06:09 PM
If the starter didn't turn over during jump (you never said?), then starter solenoid fault is likely. Although bad battery/wire connections could still be an issue.
Old Sep 26, 2012 | 06:50 PM
miraha's Avatar
Right, never started ... thanks for your help.
Old Sep 27, 2012 | 01:35 AM
miraha's Avatar
Solenoid was the problem ... thanks to everyone for the help
Old Sep 27, 2012 | 06:25 PM
Thanks for confirming the problem.
joec44
Dec 24, 2011 07:52 AM
satchmo
Jan 21, 2008 12:49 PM
fireballer44
Jan 21, 2007 04:23 PM
shaldar
Dec 13, 2006 09:55 PM
deserthonda
May 18, 2006 12:32 PM
