1993 Accord LX MT won't turn engine over
Old Apr 19, 2011 | 02:45 AM
waterskier2's Avatar
Default 1993 Accord LX MT won't turn engine over
The engine will not crank (turn over). I can hear a click 'under the dash' but not a click under the hood. I have checked the fuel pump pressure by loosening the fuel line bolt and turning the key on. I have fuel pressure. My reading the forums, I'm assuming I have eliminated the main relay under the dash, which clicks when I turn the key to start position. I have not checked the clutch switch to ensure it is completing the circuit, which I will be doing in next couple of days. If bypassing the clutch switch does not enable my starter to turn, what would be my next step? Sorry, I made a mistake in header line. I have a manual transmission.
Old Apr 19, 2011 | 05:12 PM
Check the small wire at the starter (starter signal wire). Verify that it gets 12v when the key is held in the START position.
If that gets 12v, then your clutch switch & all the rest of the circuit is OK. In that case, blame the starter.
You could also try the caveman test. Hit the starter with a broom handle or something like that, WHILE someone tries to start it.
Old Apr 21, 2011 | 11:33 PM
Hi Member..I stuck you over here to get your questions answered ..
Thank You for posting...
Old Apr 22, 2011 | 12:42 AM
Sgt.Mason.Willis's Avatar
f!@# yeah! i used to be a harrier mechanic, and when the water dump motor wouldnt open the water dump valve we would get in the main landing gear and hit that **** with a rubber mallet. worked every time... you gotta do what you gotta do. if that motor is just frozen a bit at least youll know its gonna go soon so you can go buy a new one. whew!!!
Old Apr 22, 2011 | 11:53 PM
I do not have 12v at the small wire to starter. I will be under the clutch tomorrow to see if the clutch switch is completing circuit.
Old Apr 23, 2011 | 12:19 AM
nice, thats probably a much more logical idea. hope its your solution.
Old Apr 24, 2011 | 08:16 PM
I don't have a wiring diagram for 1993. That clutch switch may act through a relay. *IF* it does, then it may be a bad switch or a bad relay. Or a broken wire somewhere.
Got a multi-meter? (so you can check each part of the circuit)
Old May 10, 2011 | 01:40 AM
Default Problem solved
It was the clutch switch. I ran out of spare time and took it to my mechanic. Thanks everyone for the input.
mattmosman
Jul 30, 2012 06:48 PM
waterskier2
Apr 19, 2011 03:37 PM
02ATownChevy
May 15, 2009 05:50 PM
Tuan
Aug 7, 2006 01:31 AM
sbclemens
Jul 24, 2006 04:34 AM
