1993 Accord, Speedometer stopped working
Old May 20, 2011 | 04:30 PM
neffster's Avatar
Default 1993 Accord, Speedometer stopped working
After a little fender bender, the speedometer, windshield wipers and cruise control stopped working. Does anyone know what might be wrong? I replaced the VSS and the Speedometer still doesnt work. Any suggestions? Thanks
Old May 20, 2011 | 04:39 PM
Where did your car get hit?
Old May 20, 2011 | 05:41 PM
neffster's Avatar
front driver side...
Old May 20, 2011 | 05:42 PM
neffster's Avatar
Also, my D4 light blinks after a certain speed.
Old May 20, 2011 | 05:46 PM
Check for engine and transmission computer codes. Read the thread in the DIY section called how to check CEL codes.
Count the check engine light flashes for the engine codes.
Count the D4 flashes for the transmission codes.
Let us know what each light flashes.
Old May 20, 2011 | 06:11 PM
neffster's Avatar
sorry, i'm a little new to this site. could you give me a link, i looked but failed to find it. thanks for the help!
Old May 20, 2011 | 07:04 PM
Old May 20, 2011 | 07:51 PM
neffster's Avatar
Great! the test worked perfectly. as far as the codes go im not sure. the engine light blinks either 7 or 8 times(not sure if the first blink counts because it stays solid a few seconds longer than the rest), and the D4 light blinks 4 times which the Code site says it is the Speed sensor which i replaced a few days ago... where do you think i should go from here? any suggestions or ideas? Thanks!
Old May 20, 2011 | 08:09 PM
The TCU code 4 is for the VSS.
The ECU code 7 is for the throttle position sensor.
Check that the connections to both of these sensors is clean and tight.
Clear the ECU and TCU memory by removing the 7.5 amp backup/radio fuse from the engine bay fuse box for a minute. Drive the car for a bit and recheck for new codes.
You may have damaged a ground or pinched some wiring when you had the fender bender. I don't think the VSS being bad would cause the wipers not to work. I think that you should look for damaged grounds.
Here is a link that you can copy and paste into your browser. It shows some of the grounds. That site doesn't have the complete 91 shop manual. You may have to do some electrical testing with a volt meter to figure out why each component is not working. It is tedious, but definitely doable. You might want to buy a shop manual for the 93. One source is to buy from Ebay in pdf form.
media.honda.co.uk/car/owner/media/manuals/accordManual/400/16-17.pdf
Old May 21, 2011 | 08:15 AM
Check ECU code again. You are likley reading code 17, VSS circuit fault. Generally, when VSS fails, both ECU and TCU set a code.
19962door
May 7, 2012 12:43 PM
dbennett3
Aug 11, 2008 11:49 PM
chill1022
Jul 19, 2006 11:14 AM
jayallen40
Dec 4, 2005 10:46 PM
88COMMUTER
May 26, 2005 10:03 PM
