1993 Accord sunroof
Old Dec 31, 2010 | 07:44 PM
dontcareo's Avatar
Default 1993 Accord sunroof
Two questions. 1) on the control buttons to operate the sunroof there is one that says ASC. It has a green light. When pushed it has a red light. What is this button for? 2) what would cause the back half (toward the trunk) of the sunroof to sag? By sag I mean when it closes the sunroof is flush with the roof but after driving it drops down a little bit causing an air leak. Thanks
Old Jan 1, 2011 | 06:37 PM
My 95 just opened and closed like a regular window. I think that the moon roof on your car can also tilt the glass like a sun roof.
I am not sure why you are getting an air leak.
I would take a look in your owner's manual to see how to operate to see if you are doing something wrong.
Old Jan 1, 2011 | 08:04 PM
There is an adjustment screw on both sides that sets the elevation. It is adjusted w/ the window retracted.
From your description, I think you have an aftermarket sunroof. I have similar buttons on my Acura 2.5TL. After figuring out the adjustment (fixed an air leak), I've never use it.
My recollection is the adjustment is similar to that described for the OEM sunroof. Check out the Online Manuals link in DIY forum for download of a 90-93 Accord manual.
Old Jan 2, 2011 | 08:51 AM
dontcareo's Avatar
Thanks for the replies. I think you're right about it being an after market moon roof. Supposedly of the DX, LX, EX, and SE models only the EX and SE had the moon roof option and mine is an LX. Also if it was a stock moon roof there would be a plug hiding a screw on the roof near the back window to close it manually with a socket if the electronics fail.
Old Jan 2, 2011 | 01:31 PM
... and I think ASC is the name of a company that does aftermarket sunroofs & convertible conversions.
jam
Oct 24, 2013 08:11 PM
spenceroma
Nov 18, 2011 12:31 PM
nhford
Apr 21, 2007 01:11 AM
cgwayland3
Mar 31, 2007 10:23 PM
yank4life
Mar 26, 2007 11:06 AM
