1993 engine change
Old Nov 13, 2008 | 03:54 PM
markwolfe07's Avatar
Default 1993 engine change
I am spending my thanksgiving (weekend?) removing and replacing my sons accord engine. 1993 F22A1 Automatic (10th anninersary model). Replacement is '92 or '93 LX engine.Past engine change experience has been on older GM and Ford makes. Interested in what special tools (if any)i willneed. Also, any tips or suggestions to help with this project would be greatly appreciated.
Old Nov 13, 2008 | 04:09 PM
finch13's Avatar
Default RE: 1993 engine change
You planning on dropping it out the bottom or hoisting it our the top?
Old Nov 13, 2008 | 04:11 PM
I would recommend changing the water pump and timing belt on the new engine while its out of the car.
Old Nov 13, 2008 | 04:19 PM
Can go bottom or top, pretty nice garage, lift, jacks etc. What's easiest? These are the sort of tips i'm looking for! (FYI my search won't work. What's up with that?)
Old Nov 13, 2008 | 04:23 PM
I personally like top, easiest just to take the tranny with it, then connect the tranny to the new engine out of the car then drop it all in.
Old Nov 13, 2008 | 04:33 PM
finch13's Avatar
I dropped my tranny out of the bottom.... that was a b****. If you have a hoist, go out the top, if you have ang engine/tranny jack.... go out the bottom.
Old Nov 13, 2008 | 04:35 PM
finch13's Avatar
Oh and be gentle when taking it out... the TPS sensor is right there.... and that is a nice spare to have and easily broken.
Old Nov 13, 2008 | 04:40 PM
about the search, it doesnt work..........at all. Use the link in finch's signature to search.
Old Nov 13, 2008 | 04:51 PM
Using a relatives garage. Hoist, jacks, air tools etc. Never heard of changing out the bottom until the other day at work. Also, heard i may need a tool for gas lines?
Old Nov 13, 2008 | 04:54 PM
not that I recall, you just unscrew a nut, then lift the fuel line off the fuel rail, as you can see in this picture where it attaches on the far left of it
