1993 ex starting issues
Old Sep 10, 2012 | 06:40 PM
ryanroper's Avatar
Default 1993 ex starting issues
So I have a 1993 honda accord ex. The issue is intermittently, I try to start it and it catches but doesnt stay running, if i half **** the key (so its in the position right before it would turn over) I can get it to stay running. This happens seemingly at random, I checked the relay (cant remember exactly what it was called) and it tested out fine with a volt meter and triggered at an appropriate voltage. Any other thoughts gents?
Old Sep 10, 2012 | 07:05 PM
This sounds like there are contact problems with the electrical portion of the ignition switch. When the engine is running, can you get the car to stall out by shaking the key?
There are some youtube videos on how to do this. The hardest part will be removing the bolts for the ignition switch assembly.
Those bolts are round, so you can't use a wrench. Some of the videos out there don't show this as a step.
Isengard2216
Nov 28, 2014 11:55 AM
Old Skool 93 Accord EX
Aug 4, 2010 08:17 PM
ramachan9
Oct 16, 2009 09:47 PM
justincollier
Sep 11, 2008 09:33 AM
bedalov
Jan 15, 2007 02:53 PM
