1993 Manual Transmission Issue Tonight
Old May 7, 2008 | 04:44 PM
RoKnAzn's Avatar
Default RE: 1993 Manual Transmission Issue Tonight
Yes, it works fine now... Its alittle rough but it is smoothing out again...What happen? Why did it happen?
Old May 7, 2008 | 10:40 PM
First, check your tranny oil level, before it gets worse.
To explain it, you gotta understand how a manual tranny works. The actual gears are always engaged, but onegear in each gearset can spin free onit's shaft.
1st & 2nd gears share a synchronizer hub between them. When you shift between 1st & 2nd you're pushing that hub back & forth between the 2 gears. Whichever direction you push it, it locks that gear to the shaft. When you push the shift lever sideways, you're hooking the lever up to a different synchro hub, say 3rd & 4th.
I think your 2nd gear got itself seized onto the shaft, so it stayed "engaged" even when you pushed the synchro hub into neutral. But you managed to break it loose so now it works.
Did I mention to check your tranny oil?? Operating without enough oil is one way to cause this to happen.
Better yet, CHANGE your gear oil. There's probably some debris from this damage so you want it out of there.
Old May 7, 2008 | 10:50 PM
RoKnAzn's Avatar
Sounds good JimBlake...I dont have a Honda Shop here. So I can get OEM parts. What brand and Type of Fuild do i need and how many?
Thanks
Anthony
Old May 7, 2008 | 11:13 PM
Honda genuine manual tranny fluid is pretty good. Honda didn't start selling that stuff until maybe'97, so your owner's manual would have called for 10w-30 engine oil.
Another choice that some people like is Pennzoil "Synchromesh" fluid.
I think2 or3 quarts, I can't remember?
Old May 8, 2008 | 12:37 AM
RoKnAzn's Avatar
Yep, My Owners Manual said 10w-30...But I guess I just use Pennzoil fluid...Good Stuff...
Thanks,
Anthony
BTW I will report tomorrow on what or not is wrong..
nickmg555
Oct 12, 2012 04:07 AM
CarIdiot
Jun 9, 2011 09:52 AM
importedminds
Jul 16, 2008 10:31 AM
May 15, 2008 12:10 AM
19Accord97
Feb 16, 2008 02:13 PM
