1993 no start
Old Apr 30, 2011 | 08:24 AM
WIAccord's Avatar
Default 1993 no start
OK, so now that the cooling issue is resolved, the car will not start now. It cranks over fine and tries to fire but will not start and stay running. I did clean the AIC and cleaned and adjusted the FITV. I also checked the starting valve and it will not hold a vacuum. I checked it with a Mityvac, according to the repair manual it should hold a vacuum. Could this be the problem? Or is it the AIC or FITV that could be causing the issue? Plugs, wires, cap are all almost new, so I'm not thinking it is an ignition issue.
Old Apr 30, 2011 | 08:43 AM
Regarding AIC or FITV, suggest trying to start w/ slightly cracked throttle. If this causes a good start, then these parts may be at fault. Both seem to be non-performing.
Suggest attempting to start w/ starter fluid or throttle body cleaner sprayed into throttle body intake. A good long 3-5 second shot. Immediately start car. If it runs for a few secs and dies, then ignition is OK and fuel delivery is problem. If it fails to start, you have lack of spark.
Confirm no spark w/ an inductive timing light attached to one lead. Turn engine over, no flash or missing flashes means no or intermittent spark.
Old Apr 30, 2011 | 12:26 PM
WIAccord's Avatar
Ok, tried the part throttle start. Still will not stay start or run. It fires but that is it.
I'll try the starting fluid later, have to go pick some up. Also will check spark. I didn't have these issues before cleaning the IAC. Figured it was the FITV so cleaned that and adjusted it too. Still didn't fix it.
Old Apr 30, 2011 | 12:50 PM
Double check all of your wrk, not too much has to be removed to get to those but if the wire connector isn't on........
Could it be somewhat flooded? by now I would think the cleaner would be gone, had to ask.
Old Apr 30, 2011 | 04:13 PM
WIAccord's Avatar
I'll go over everything again. Also, I let the parts sit for at least 30 minutes before re installing them. I'd think the cleaner had dissipated by then.
Tony1M
Nov 6, 2023 08:29 PM
fastfox1306
Jan 19, 2021 09:32 AM
Julieanne1976
Aug 21, 2009 09:20 PM
markwolfe07
Dec 3, 2008 07:22 PM
MA93Accord
Nov 3, 2008 08:03 AM
