1994 Accord 2.2 v-tec automatic
Old Sep 19, 2011 | 11:31 AM
covered's Avatar
Default 1994 Accord 2.2 v-tec automatic
picked up vibration @ idle however tach does not reflect this.Once underway vibration goes away,tried wires,plugs,cleaned throttle body,no codes.I just remembered the drivers side motor mount leaked out fluid around a month ago- could this be the cause????? if not any suggestions - 110k miles with no mods - all stock - dealer serviced
ths
Old Sep 19, 2011 | 11:50 AM
Yes, unfortunately the motor mounts front and rear are prone to failure w/ age. Front is easy DIY, however rear is an advance diy.
You can see the rear motor mount from pax side of car w/ a good light. Have someone (trusted) put car in forward and reverse (while holding foot brake and hand brake firmly set) w/ small throttle spikes to 1500-2000 rpm. Watch the rear motor mount. You can see excess movement and failed rubber mount. Check DIY section for replacement procedure.
I used the underside work procedure; elevate car on jack stands, remove drive axle and access from underneath for removal.
Front mount can be visually inspected easily.
Post moved to correct forum.
Old Sep 19, 2011 | 12:46 PM
covered's Avatar
Default 1994 accord 2.2 v-tec
tks Ill change it out
Old Sep 19, 2011 | 05:26 PM
You can also try grabbing the valve cover to push/pull on the engine to see if you have play in any of the motor mounts.
Old Sep 19, 2011 | 05:51 PM
That rear mount is vacuum-operated on auto-trans cars. Possibly the solenoid valve is the problem? Check for vacuum vs. no-vacuum at the rear mount, when you shift between P and R with the engine idling.
Old Sep 20, 2011 | 07:14 AM
covered's Avatar
tks to all who replied -
faran
Aug 1, 2016 06:07 PM
martinez289
Mar 1, 2013 06:33 AM
Bilster
Sep 7, 2011 03:36 PM
jitterjuice
Jul 27, 2011 07:55 PM
Ronnie101
Jun 21, 2007 09:44 PM
