1994 Accord EX (Automatic) - Speedometer problem
Old Jun 12, 2014 | 06:15 PM
honda-fan's Avatar
Default 1994 Accord EX (Automatic) - Speedometer problem
My 1994 Accord EX speedometer sometimes dies. Occassionally when it dies I see the D4 light flashing. Is this a VSS problem?
Old Jun 12, 2014 | 07:23 PM
It could be the VSS, the wiring, or the computers.
Check for engine and transmission codes. See the common diy thread on top of the gen tech help forum for a how to check cel link.
Does the cruise control work when the speedometer goes out?
Old Jun 13, 2014 | 07:32 AM
the 18th letter's Avatar
I've got the same car with the same problem. My cruise will work even though the speedometer doesn't.
Old Jun 13, 2014 | 04:06 PM
honda-fan's Avatar
Could not get to check the cruise control. However, today the speedo died again accompanied by the flashing D4 light. D4 continued to flash even after the speedometer recovered. No check engine light at all - any thoughts?
Old Jun 13, 2014 | 07:21 PM
Check for engine and transmission codes. See the common diy thread on top of the gen tech help forum for a how to check cel link. It is the same procedure for the transmission codes.
The codes are stored, so the light doesn't have to be flashing for you to retrieve the codes.
Old Jun 14, 2014 | 09:24 PM
turbofrank's Avatar
Same thing happened to me 1.5 yrs ago it was VSS. My tac went crazy too during D4 flashing. Same thing started last week again. This time i may buy Honda part. Last one came from Advance or Autozone.
Old Jun 16, 2014 | 11:24 PM
honda-fan's Avatar
Problem solved. It was vss. As was mentioned by others, speedo fails, d4 flashes and cruise does not engage.
Old Jun 25, 2014 | 08:46 PM
HondaFan18's Avatar
I have a similar issue in my 95 Accord V6. Speedometer stuck at 20MPH, but no flashing D4 light, and cruise control works, therefor the VSS is good. I'm told it's the speedometer circuitry. Playing with the trip odometer reset button seems to make speedo work sometimes as suggested in previous threads...
Anyone know where I can find a schematic?
Old Jun 26, 2014 | 10:00 AM
The 94 Honda shop manual has a partial circuit diagram. It shows pin no's and basic circuits but I suspect there are other items such as power conditioning that might not be shown. Not aware of any detailed circuit diagrams.
Others have had some luck w/ visual detection of defects and resoldering the circuit solder jts.
Shop manual is helpful to enable gauge panel removal. Check DIY forum and youtube also.
faran
Aug 1, 2016 06:07 PM
RaysHondaAccord1994with247.000miles
Oct 31, 2011 06:27 PM
saleemb
Apr 29, 2010 09:51 PM
Ronnie101
Jun 21, 2007 09:44 PM
cbriley3
Oct 23, 2005 11:04 PM
