1994 accord ex engine knock
Old May 4, 2009 | 01:24 PM
Since you had to fill up the radiator, you may have a leak. Keep a close eye on the coolant level. If it drops quickly, then you probably have a leak.
Old May 6, 2009 | 09:54 PM
fusionstar's Avatar
Thanks, Changed the thermostat and the overheating problem is gone. I am on 100% water but will have it flushed and will have the recommended coolant. I believe my radiator is clogged, the flow of water is very low and although the car doesn't overheat anymore, the radiator hoses get very very hot and become pressurized after 20 minutes on the freeway. It is almost hard to squeeze but its very easy when its cool.
Old May 7, 2009 | 08:18 AM
Anti-freeze not only lowers the freezing temperature, but it also raises the boiling temperature. Along with corrosion protection. I wouldn't go for more than an hour or 2 without the corrosion inhibitors.
tkj860
Oct 9, 2014 03:24 PM
cc23
Oct 15, 2013 10:11 AM
dave1977nj
Feb 28, 2011 10:41 AM
rmistry7
Sep 28, 2006 05:05 PM
Jan 18, 2005 07:46 AM
