1994 Accord LX Alternator Brush Assembly
Old Jan 2, 2011 | 10:08 PM
You should be able to pull back that rubber boot to release that electrical connector.
Old Jan 3, 2011 | 01:50 AM
slickster's Avatar
Default 1994 Accord LX Alternator Brush Assembly
Suggest downloading the 94-97 Accord Manual from Online Manuals links in DIY forum.
I've been looking all over for such a link in the DIY forum but could not find it. Can you copy the link here?
Thanks.
Old Jan 3, 2011 | 02:23 AM
https://www.hondaaccordforum.com/for...ead.php?t=4597
The spooner link in this thread has it. Is is called Accord 1994 CD7 CD9 USDM JDM Service Manual
Old Jan 3, 2011 | 11:43 AM
slickster's Avatar
Thanks for the manual download links. I'll see if any of those has more detailed info than my Helms Service Manual.
Old Jan 4, 2011 | 03:27 AM
slickster's Avatar
Thumbs up Completed: Accord LX Alternator Brush Assembly
You were right; it was easier than I thought and thanks to your help and that of others I was finally able to finish the brush replacement successfully. The only difficult -- and I mean *really difficult* -- part of the job was to install the new assembly with retracted brushes. Eventually I had to improvise a special tool just for that. The alternator is now charging non-stop whenever the car is running.
Here is the picture of the alternator with the back cover and the old brush assembly removed:
You might notice a minor corrosion on the 4-prong connector that resembles what you can often see on battery terminals. Unfortunately this one is not as easy to clean as the battery though.
Here is a picture of the old and new brush assemblies for comparison. As you see the old brushes were really worn down:
Oh, and thanks for the downloadable manual links as well. For me the really useful part was the supplement because the main manual I have is the same one as the one at those links.
So thanks again to all of you who contributed to this thread.
Old Jan 25, 2011 | 02:22 PM
Bad_dude's Avatar
So which part of the brush that was difficult to install? The pic of the new brush, are those graphite component suppose to be pushed down?
Thanks.
Old Jan 25, 2011 | 03:06 PM
  #17
slickster's Avatar
Post
Thanks.
Those two graphite brushes were needed to be retracted for the assembly before slipping the brush assembly over the brass rings. Each of the brushes is supposed to contact one of the rings for the current to be transferred to the rotor's electro-magnet. The brushes are spring-loaded to provide sufficient friction against the brass rings.
Old Jan 25, 2011 | 03:51 PM
  #18
Bad_dude's Avatar
Question
Thanks. So would you push them down to install onto the brass ring? I saw the one video online but that alternator brush installation is different than Hondas. So any tip?
Thanks.
Old Jan 25, 2011 | 08:09 PM
  #19
slickster's Avatar
Post 1994 Accord LX Alternator Brush Assembly
Yes, you do push in those two brushes somehow temporarily into the brown cube of the brush assembly in order to be able to slip the whole thing on rotor's slip rings. What might help you is a piece of thin-wall tube that could hold the brushes pushed in while you install the assembly. Then you pull the tube out and screw in the two Philips head screws that secure the brush assembly. You might think of some other temporary tool that would do the job, such as a U shaped metal piece. You can't do that with your fingers alone.
Old Jan 26, 2011 | 12:03 PM
  #20
Bad_dude's Avatar
Question
How much room do I have to put something in to hold it down? Would a toothpick works?
Thanks.
