1994 Honda Accord with 247.000 Speedometer etc.
Old Aug 11, 2011 | 11:02 PM
RaysHondaAccord1994with247.000miles's Avatar
Thanks for the address will call him. I have never used the cruise control but will tr just to see if is the VSS. Thanks for your help. Ray In LBC.
Old Oct 30, 2011 | 10:47 PM
JoeJoe77's Avatar
I've changed both the VSS and the speedo cluster, verified wiring was good, still get intermittent speedometer and odometer.. Any suggestions?? When chaged both seemed to work fine for a day or two.. Really need help as frustarted. I have a 94 Honda Accord Ex???
Old Oct 31, 2011 | 08:35 AM
wunderbra's Avatar
Time to start checking for good connections in the harness. Look at the plug for the VSS and make sure it is not corroded or oily.
Old Oct 31, 2011 | 06:27 PM
Default VSS switch
Took my car in for a replacement switch $225.00 for the new Honda VSS switch and $75.00 for labor. I 'd say 1 is it a new switch. 2 is it genuine Honda part. 3 is the repair shop good with good recommendations. If all is yes then as mentioned check the connections as something may have come loose. My Honda has been fine since it was replaced 2 months ago and it does drive a little smoother with the switch and thank god that D4 light isn't blinking anymore. Good luck.
Cateastrophe
Feb 8, 2013 06:56 AM
Teek
Feb 23, 2012 09:08 PM
saleemb
Apr 29, 2010 09:51 PM
Mar 6, 2007 08:27 PM
cbriley3
Oct 23, 2005 11:04 PM
