1994 Honda Accord Ex
Old May 24, 2011 | 01:06 AM
94ex915's Avatar
Almost A Senior Member
Default 1994 Honda Accord Ex
So my girlfriend just bought a 1994 Honda accord. I'm trying to do all the maintenance for her and I'm trying to figure out a few problems.
First of all there is a ticking noise coming from the engine. Can really only be heard at a stop light or when parked or whatever.
Another thing is, the is a grinding noise coming from the back of the car when the brakes are applied. Doesn't do it all the time. We are replacing the pads tomorrow and I'm hoping this will fix it. I'm new to this whole Honda thing. I myself own a 95 tsi but I'm really considering a Honda accord for my next car.
Thanks in advance for the help.
Old May 24, 2011 | 05:49 AM
Ticking noise is likely a slightly loose valve. If noise disappears on full warmup, I would leave alone. If persistent, you can adjust the valves. Get a shop manual (check Online Manuals links for emanaul).
Grinding noise is likely brake pads worn out and damagin the rotor. You may need a new rear brake rotor. Easy replacement. Most have reported acceptable performance from Chinese aftermarket rotors.
Old May 24, 2011 | 11:06 PM
94ex915's Avatar
The sound stays all the time.
And ya I'm going to do the brakes and get the rotors turned. Thanks much for your help. I appreciate it.
Old May 25, 2011 | 12:00 AM
Most rotors can't be turned correctly anymore so go for the new ones...
Old May 25, 2011 | 12:32 AM
94ex915's Avatar
Oh and about the valves, is it a major problem if I dont get them adjusted?
Old May 25, 2011 | 05:49 AM
I've never heard of any consequences of loose valves other than some loss of engine efficiency.
Old May 25, 2011 | 09:11 PM
Excess wear on the system, sometimes emissons can be impacted....but as stated, nothing major.
Old May 26, 2011 | 11:24 AM
94ex915's Avatar
And now that I really listen to the noise I can't tell if it's coming from the engine or the belts. The sound can only be heard at low rpms.
Old May 26, 2011 | 12:29 PM
You can sequentially disable the PS and AC/Alternator accessory belts and see if noise stops.
W/ accessory belts removed it should be possible to use a stethoscope or listening tube to isolate if sound is coming from under timing belt cover. Problems here could be a worn idler, loose or worn timing belt, or water pump bearing.
faran
Aug 1, 2016 06:07 PM
dswiz1984
Oct 17, 2008 09:10 PM
abhijitgp
Aug 21, 2006 12:53 PM
AbsoluteOblivi0n
Apr 19, 2006 10:14 AM
Apr 10, 2005 12:22 PM
