1994 Honda Accord EX vtec
Old Sep 10, 2020 | 12:11 PM
Mr94's Avatar
Default 1994 Honda Accord EX vtec
1994 Honda Accord EX vtec, engine shakes and vibrates around 1000r/min
Also also change the spark plugs.
Old Sep 10, 2020 | 06:26 PM
Please provide more information about the issue. Does this happen when idling or a certain rpm? Does it happen all the time?
Is the check engine light turning on or the D4 light flashing? You should check for codes regardless. See the check cel codes writeup in the common diy thread on top of the gen tech help forum.
Any recent work on the car?
Old Sep 10, 2020 | 08:31 PM
Also, how many miles on the car? Is the normal maintenance up-to-date, like spark plugs?
Did it start with a fuel fillup? (bad gasoline?)
(The ideas will probably be scattered all over the place until we learn more details about what's happenning)
Old Sep 11, 2020 | 08:27 AM
Mr94's Avatar
Good morning when I first start up the Honda Accord it then after 5 minutes it starts to shake and vibrate and then while I'm at stoplight it will cut off.
I recently replaced the EGR valve the ECU computer and the distributor. The spark plugs been replaced about a year ago. The check engine light isn't on and the d4 either.
Old Sep 11, 2020 | 11:14 AM
Mr94's Avatar
Default Spark plug firing order 94 Honda Accord EX vtec
The best spark plugs used spark plugs for tuning up a Honda Accord EX vtec.
Old Sep 11, 2020 | 11:18 AM
Seanjordan20's Avatar
I always use NGK Laser Platinum plugs in all my cars. They last for at least 100k.
Old Sep 11, 2020 | 11:21 AM
Mr94's Avatar
Default Distributors?
Hey I got a 1994 Honda Accord EX VTEC which distributors better AutoZone or used Honda distributor.
Old Sep 11, 2020 | 11:47 AM
A distributor that works. I buy them off Amazon if they have a good warranty. Just replaced a civics that came with a 5 year warranty. If the price is reasonable and autozone has a good price then buy it.
Old Sep 12, 2020 | 10:44 PM
nomad2020's Avatar
does engine shake cause of an engine miss ot does engine run even and it could be broken motor mounts if it has AT.
i would not replace any more parts till you figure out exactly what the issue is
lanjeer
Sep 18, 2014 06:00 PM
jitterjuice
Jul 27, 2011 07:55 PM
torrguy
Jul 18, 2011 06:01 AM
haddad joe
May 21, 2010 06:35 AM
mbnjagn
Jan 2, 2009 11:16 PM
