1994 Honda Accord LX Transmission Computer (TCM/TCU)
Old Sep 12, 2009 | 02:12 PM
atlsk8crewboi22's Avatar
Question 1994 Honda Accord LX Transmission Computer (TCM/TCU)
When i bought my honda accord from a private seller, he told me that all it needed was a transmission computer because it has problems shifting. If i leave it in D3 it will stay in 3rd gear and my D4 light doesnt come on at all neither my needle lights come on so idk wats up with all that but i have to manually shift it (only 2nd & 3rd gear) NO 1st shift. So i went on ebay and got one and it finally came in yesterday, i removed it and installed the one i just got and it still does the same thing. What else could be wrong?
Old Sep 12, 2009 | 02:21 PM
Exclamation Please, No Links To Your Space
Also no links to my space either..not direct ones..
Thanks
Old Sep 12, 2009 | 02:34 PM
my bad....
Old Sep 12, 2009 | 03:34 PM
There can be all sorts of things that can cause your problems.
I think that you will need to figure out why the D4 bulb is not turning on. It could be a burned out bulb, the a/t gear position switch, or the wiring. Once you have a working D4 light, then you can short the service connector and see if any TCU codes are stored. You may want to short the service connector anyway and see if the D4 light flashes.
I would download the 94 shop manual from the links in the Online Manuals thread in the DIY section. 23-163 is the start of the section you want to look at. And 23-168 has the continuity tests for the gear position switch.
Old Sep 15, 2009 | 04:02 AM
could my main relay be an issue as well cuz even when i put the car in 1st gear it stays in second then when i put it in d3 it will go into 3rd gear fine...
Old Sep 15, 2009 | 06:52 AM
If the main relay were the problem, the engine wouldn't be running.
PA listed possibilities - check them out.
Old Sep 17, 2009 | 02:51 AM
ok ill keep yall posted on wat happens
Old Sep 21, 2009 | 12:39 AM
i have a question...if the transmission computer was fried it wouldnt shift from 2nd to 3rd when its in d3 right?
fixitgirl29
Jan 13, 2015 12:14 AM
rickthefix
Jun 13, 2014 06:25 AM
Brandon Saunders
Mar 18, 2013 12:25 AM
leah500
Dec 20, 2012 11:50 PM
Dane0vin
Oct 28, 2011 06:20 PM
