1994 honda accord, rough idle, power loss
Old Oct 8, 2012 | 09:56 AM
inkuyo's Avatar
Default 1994 honda accord, rough idle, power loss
I have a 1994 honda accord, manual transmission.
I recently had the timing belt, water pump and belts changed (about 2 months).
now I don't drive this a lot, but I was going 60 on the freeway when I suddenly had a power loss. I pulled over and shut down. I could restart and it would run run for a little, albeit roughly.
NO CODES indicated at all
I replaced the wires and the plugs, checked spark, checked compression all is good. I noticed the oil sensor was unplugged and replugged it. It does have oil. I removed a hose from the IAC valve to see if there was a vacumn and then it won't start unless I hold the peddle to the metal. I am getting a lot of backflow out the air filter too.
That said I am gassing the plugs when I do that. Also,
I loosened the extension between the exhaust manifold and the catalytic convertor thinking maybe I had a plugged convertor. Still not starting.
Any ideas?
Old Oct 8, 2012 | 12:34 PM
Suggest following checks:
Timing - Check that Crankshaft TDC and camshaft TDC are aligned. You will need to remove the upper timing belt cover to see alignment mark on camshaft sprocket. A horizontal mark on the front of engine side of the sprocket should align w/ the top edge of rear side of timing belt cover attached to engine.
Check for large vacuum leak; PCV, brake booster, ejected forward balance shaft seal (massive oil leak would accompany this failure).
Check fuel pressure w/ engine off by turning keyswitch to On for 5 secs, then off. Wait 30 secs and crack banjo bolt on fuel rail. You should get a powerful spray of fuel (40 psi pressure). If no spray, fuel is leaking somewhere.
Check distributor cap and rotor for cracks which could short spark to ground.
Kpick
May 5, 2015 08:51 PM
phantomgrey92
Aug 22, 2013 07:42 PM
HatchJunki
Mar 9, 2013 08:23 AM
alphamoon70
Aug 26, 2011 12:05 PM
fchidahonda
Jul 11, 2011 01:41 PM
