1995 4 door leaking driver rear carpet
Old Apr 12, 2010 | 11:29 AM
ECV4LIFE's Avatar
Default 1995 4 door leaking driver rear carpet
Hello Guys,
I really need some help with my Accord. I am getting quite a bit of water in the driver side rear floor. It's bad enough to soak up to the front driver side. I can't seem to see where it's comming in from. Any help would be much appreciated.
Old Apr 12, 2010 | 08:59 PM
The leak could come from several sources. A bad seal on a window or the trunk.
I would also check that the drain tubes are not plugged up if you have a moon roof. I attached a pic of how the tubes are routed.
mtairymd
Jul 30, 2015 08:05 PM
jza240sx
Apr 30, 2013 04:14 PM
pnyklr
May 16, 2011 05:43 PM
djrockewfewtimez986
Jul 6, 2010 05:34 PM
soba_03
Jun 23, 2010 02:21 PM
