1995 Accord D4 Blinking Lights - Multiple Codes
Old Sep 3, 2011 | 06:54 PM
narshank's Avatar
Default 1995 Accord D4 Blinking Lights - Multiple Codes
Hi,
Thanks for this site. Great stuff.
I have a 1995 Honda Accord EX Sedan 4 Speed Automatic Transmission. Its VIN indicates that it was made in Japan. It has over 220,000 miles on it. Drives beautifully, till now!
A few days ago I cranked up the car and it started normally. Changed the Shift to 'D4' and then turned on the AC, about to drive. AC turned on normally. But I realized that I had forgotten to pick up something and so I changed the Shift back to 'P' and the car went dead. I was not able to start the car again. It cranks just fine, but does not start. I then noticed that the D4 light kept blinking.
Based on the posts on this site, I retrieved the OBD codes manually. One of the post recommended clearing the codes by removing the 7.5 Fuse for the backup radio, which I did. I also removed the -ve battery cables for about 15 mins to clear any memory (though not sure if it helps).
So when I retrieved the codes I got the following:
1 8 13 and 14.
The Engine Check Light is a steady yellow.
I have a previous SRS problem that I have not fixed yet. When I did the above test, the SRS light on the dashboard was also blinking.
There were other posts on this site that suggested that this condition is due to a faulty ECM.
My question is, if this a certain diagnosis? Or can I do anything else to confirm before I purchase a new/used part.
If I removed the ECM, can I do any basic functional test with a multimeter to confirm that it is faulty.
Also is it safe for me to change the ECM myself? I can do a number of basic jobs (like changing light bulbs, etc.) but I am no mechanic and I don't have any sophisticated tools.
I also did try and read other posts as many as I could. But I may have missed something out. So please do direct me to another post if this problem is already covered.
Any help would be appreciated.
Thanks very much.
complex92
May 23, 2015 08:59 AM
rdimpulser6
Oct 10, 2011 11:45 AM
KHonda
Apr 17, 2010 12:57 PM
coup de grace
Jun 8, 2008 01:39 PM
