1995 Honda Accord 2.7L
Old Oct 28, 2024 | 02:33 PM
btartus's Avatar
Default 1995 Honda Accord 2.7L
so this hose in the back connects into the firewall and looks like its had its day. very dry rotted. no idea what its for.
Old Oct 28, 2024 | 03:34 PM
Best guess is these are the heater hoses bringing hot coolant to the heater unit inside the car. To get a better idea, trace each hose and find where it connects at the other end. If it is a heater hose, then one of those two hoses entering the firewall will connect to a valve controlled by turning the temperature **** inside the car to controll coolant flow.
Old Oct 28, 2024 | 03:47 PM
btartus's Avatar
ok great. I live in Florida never use the heater lol but I will figure it out after I take care of the A/C hoses. thank you!
Old Oct 28, 2024 | 03:57 PM
Understood. If those hoses are leaking with the heat shut off, you will loose coolant and could potentially have the engine overheat. Just inspect when the engine is warmed up for leaks. I'd replace in the near future as overheating the engine can turn into an expensive repair (head gasket and cylinder head machining). Keep an eye on your coolan level in the radiator when the engine is cold.
You can price out the prebent hoses at the parts stores. The prebent are better for routing vs the cheaper flexible hose that could get kinked or want to rest against something hot like the engine block.
Old Oct 28, 2024 | 04:15 PM
btartus's Avatar
it seems its leaking at the connector, not the hoses itself, but will required replacing the hoses. I understand about the prebent hoses vs. cheap flexible. my radiator is perfect, no cooling issues. I will figure out the big hose going into the engine bay. thanks!
2QuickT
Jul 19, 2023 01:28 PM
kineticfaith
Jul 12, 2022 08:52 PM
TexomaAccord
Feb 18, 2019 08:23 AM
jtkj
Nov 9, 2009 11:42 AM
top2
Oct 8, 2005 07:37 PM
