1995 Honda Accord EX A/C problems
I am new to this but thought I would try. I am having trouble with my air conditioning in a 1995 Honda Accord. I checked the relays, fuses and unclogged the drain b ut my air is still blowing warm and the compressor does not seem to be kicking in like it used to when the a/c button is engauged, please help?????
Read the posting rules! I moved your post to correct forum.
Is the compressor engaging rarely, or never? Has it worked correctly recently or not for some time?
Not much can be done w/o ac manifold pressure gauges. Do you have a set and know how to use?
If compressor never engages, you can remove the hi/lo pressure cut-out switch and short the connections. If compressor engages (only run a few secs!, system can be damaged if run too long), then likely cause of problem is low system pressure. Hi/lo pressure switch disables compressor if system pressure is too low or too high.
marysmom
Mar 31, 2012 07:30 AM
1995, 95, ac, accord, air, checking, compressor, conditioner, find, fuse, honda, problem, problems, troubleshoot, weak
