1995 Ignition Switch replacement
Old Jun 20, 2006 | 07:33 PM
Fergy
Default 1995 Ignition Switch replacement
Any helpful tips on replacing the electrical component only of the ignition switch in a 95 Accord LX? The Helm manual says to drill out the shear bolts holding the entire assembly to the steering column. I don't see a way to remove the electrical component without removing the shear bolts. I thought someone here may have a less intrusive means to accomplish the removal. Thanks in advance for any help.
Steve
Old Jun 21, 2006 | 04:58 AM
deserthonda's Avatar
Default RE: 1995 Ignition Switch replacement
http://techauto.te.funpic.org/ignitionswitch.php
take a look at the link above ..
you need to remove the switch completely out of the car otherwise you cannot get to the screw for the electrical portion,,,,,,,,
you DO NOT have to drill the sheared bolts, once you remove the steering wheel covers ,, get a sharp punch and a hammer and hit the sheared switch bolts counterclock wise to remove them,, .. that's how i do it and it works great.. those bolts are not very tight at all..
Old Jun 22, 2006 | 12:55 AM
Fergy
That was exactly the sort of tip I needed. Everything went like a charm as you said. Thanks again for the information.
Old Jun 22, 2006 | 03:41 AM
ORIGINAL: Fergy
Glad that it worked out ..
Matthew Kniss
Jun 30, 2014 06:00 PM
stubby1962
Feb 24, 2013 10:39 AM
shehadehd
Sep 20, 2012 05:20 PM
Mikee Anderson
Sep 10, 2012 06:27 PM
Mikebike125
Jan 18, 2008 07:07 PM
