1995 lx fun build
Old Dec 30, 2021 | 04:43 PM
Highguy9122's Avatar
Default 1995 lx fun build
I got a 95 lx with a f22b2 in the backyard. Got it to run but it clearly has severe cooling, transmission suspension issues. So just for the he*l of it I decided to do a full build (mechanical). With a 10k budget I want max fuel efficiency as well as power it also has to stay auto 😥. Any suggestions?
Old Dec 30, 2021 | 09:08 PM
shipo's Avatar
When it comes to builds, there are typically options (pick any two of the three):
  1. High power
  2. High reliability
  3. Low cost
In your case it seems you want to replace "Low cost" with "Good fuel economy"; unfortunately the "Pick any two of the three" adage still holds true.
Old Dec 30, 2021 | 11:26 PM
Replied to your other post. For max power, you may want to consider a H22 engine/trans from a prelude. That is a common swap. The F20 engine is a bit less common, but a lot of info on that swap. The reliability comes from Honda engines being fairly reliable, just make sure you do the homework on the swap.
The engine you install depends on what you want for performance vs fuel economy.
NINETY5LX
Jul 27, 2025 09:33 AM
btartus
Nov 13, 2021 05:45 PM
hondaRacer
Mar 19, 2012 07:17 PM
ballzyfbaby
Aug 18, 2009 12:50 PM
flipmew3
May 8, 2005 10:47 AM
