1996 2.2 accord a/c problem
Old Mar 11, 2007 | 03:58 PM
robert7
Default 1996 2.2 accord a/c problem
HI THERE.MY A/C STOP COOLING.THERE WERE BAD ODORS INSIDE THE CABIN.WE ADD GAS , THERE WERENO LEAKS UNDER THE HOOD AREA. COMPRESSOR ,LINES ETC. THE PROBLEM SEEMS TO BE UNDER THE DASH AREA. THE QUESTION IS HOW DO I KNOW IS THE EVAPORATOR?
DOES IT GET PLUGED OR COULD IT EXPLODE? CAN I JUST CLEAN IT? COULD IT BE THE EXPANSION VALVE.HOW DO I CHECK THIS ONE IS OK. THANKS IN ADVANCE
Old Mar 11, 2007 | 04:18 PM
deserthonda's Avatar
Default RE: 1996 2.2 accord a/c problem
Hello Robert,, First off i want to Welcome you to HAF...
You might have a leak inside the evap core , i have seen it many times ,, if you keep on losing freon and there is no other leak in the engine compartment than the evap is most likely it,,
Now there are many reasons why the a/c stops working.. first thing you need to do is hook a pressure gauge and see what they read,, if there is freon in the system it could be an electrical problem I need more info to properly diagnose your issue ..
has anyone put dye into the a/c system ??
if the evap is not leaking, you can remove it and properly clean it with soap and water and at the same time i would replace the upper and lower foam insulators ,spray some fridgy fresh or some lysol disinfectant , that should get rid of the bad odor
And NO it does not explode ,, you are safe ,,
so first things first.,, is there any freon ? if no, diagnose and repair leak,
if there is freon is there power at the compressor red wire ? engine runing . a/c on ? if not chk fuses, relay,
do that and let us know
Old Mar 11, 2007 | 04:33 PM
robert7
HI. IF THERE ARE A LEAK INSIDE THE EVAPORATOR. CAN THIS BE FIX WITH PRODUCTS LIKE MAXI SEAL OR IS JUST BETTER TO REPLACE IT WITH A NEW ONE?IF SO WHAT YOU RECOMMEND?
Old Mar 11, 2007 | 09:38 PM
hondadude's Avatar
I would recommend you stop SHOUTING at the people trying to help you.
I would not add any type of 'sealer' to the A/C system it can cause other problems.
The most common leak in the evaporator case is the 'O' rings at the expansion valve fittings, so it is not needed to replace the entire evaporator.
Old Jun 21, 2011 | 04:57 AM
prem1114's Avatar
Default 96 accord 2.2L a/c problem
I have replaced my ac compressor along with getting my system recharged and my air is just blowing out cool i cannot get it to blow cold air out.I have a new born and must fix my ac asap any suggestions?? My next step was to replace my evaporator both the one in front of the radiator along with the one in the dash bored
Old Jun 21, 2011 | 05:56 PM
Can I assume this is the same year as the OP? Do you have a volt meter?
IF the system IS charged, please don't throw more parts at it without testing a few things.
Tandem2
Apr 8, 2012 10:14 PM
sskautos
Apr 27, 2011 06:26 AM
stockxplorer
Jan 29, 2011 01:22 PM
ThatOneGuy352
Oct 30, 2010 08:13 PM
bebo189
Oct 14, 2008 08:51 AM
