1996 Accord ABS brakes
Old Nov 24, 2005 | 11:22 PM
MichaelEXL's Avatar
Default 1996 Accord ABS brakes
Has anyone ever replaced the ABS light on an Accord, the dealer told me the parts are $1500.00 plus labor. Today tried to unplug the dashlist so it will stop showing up, but can't pull the fuse. My car has 170,000 miles on it. Dealer told me it was ok to drive, but unsure, advised me will t ill have brakes. This is all confusing to me.
Can anyone advised me ?
Thanks
Michael
Old Nov 24, 2005 | 11:23 PM
MichaelEXL's Avatar
Default RE: 1996 Accord ABS brakes
I meant the ABS modular not the light on the dash itsself.
Old Nov 30, 2005 | 01:46 PM
MichaelEXL's Avatar
Well American Honda won't pay for replacement due to mileage, but the dealer offered a discount, the part alone is $1,500.00 so that will have to wait for sure.
Old Dec 4, 2005 | 10:04 PM
deserthonda's Avatar
find out if they want to replace the modulator because it leaks,if so, tell them you want them to reseal it ,,,, removing fuses and relays will not stop abs lite from coming on, you need to either repair problem or remove the bulb
Old Dec 5, 2005 | 12:46 AM
MichaelEXL's Avatar
Well found out on Friday that this is a common problem for the Accord is the ABS to go out. I have meet anotehr woman at the dealer in Gainesville Friday, she was having the samething done.
Makes me wonder how many more people are having the same problem.
Also tonight the light went out on its own, very strange indeed.
Did a quick stop to test, and seems the ABS is working again.
Old Dec 7, 2005 | 09:40 PM
MichaelEXL's Avatar
As of today, the light went out automatically, and seems I have ABS brakes again, this weird to me.
Thanks for letting me post.
Old Jan 19, 2006 | 06:41 AM
MichaelEXL's Avatar
Well earlier this week , the light for the ABS came back on, tried adding brake fluid it didn't work. An ymore ideas I would appreciate them.
Old Jan 19, 2006 | 07:11 AM
lightshow's Avatar
yea you have an abs problem and you need that part replaced. you can do it yourself for a fraction of the cost that the dealer wants. turning of the light....whichever way you want to do that......will not make the problem go away. your braking system will still work you just wont have abs so when an emergency situation happens, your tires will completely lock up and you may go into a slide. if your not familiar with sliding and or drifting, and maybe even find it enjoyable , its a good idea to get the problem fixed.....we dont want anything bad to happen to you. thats why almost every single car now has ABS because it is just so much safer. when the tires dont lock up, the car can be controlled in a emergency maneuver. you should get it fixed or get a new car.
lightshow
Old Jan 19, 2006 | 07:16 AM
lightshow's Avatar
and you said "another woman" i take this to mean that you are also a woman. not being sexist or anything, but outside of you being danica patrick, women are normally not very good at sliding. my gf has abs on her car, and if a problem occured today, it would be fixed yesterday. there is no way i would have her driving a car without abs, it would def be disasterous.
Old Jan 21, 2006 | 02:06 AM
ORIGINAL: MichaelEXL
What is the code???? pull the code and post it here ...And i asked this once before why did the dealer say that you need the modulator?? is it leaking ?? If it is because it leaks , Modulators can be resealed ,,,
