1996 Accord EX 4 cylinder starting issue
Old Nov 25, 2021 | 11:54 AM
Dennylh's Avatar
Default 1996 Accord EX 4 cylinder starting issue
4 cylinder, manual transmission. I would drive to work park it, come back turn the ignition and nothing. Could compression start it to get home. Replaced both switches on clutch pedal, ignition switch, starter, battery (today) Getting nothing today, turning ignition doesn’t even come on now. Checked fuses, cables appear ok. Not having any power to the interior is new. Need to solve that problem, then get to the no turnover, starter activation issue.
Old Nov 27, 2021 | 08:12 PM
I would probably use a test light to check all of the fuses have power while in place. Search how to check car fuses in place on youtube for a good video.
This tells you if the fuse is good and if the fuse is getting power at the same time.
rta1023
Sep 15, 2021 08:05 AM
Tmackerley
May 20, 2021 11:25 PM
einuj
Jul 18, 2017 06:33 PM
MRMASON
Oct 3, 2006 07:15 PM
