1996 accord lx...help please
Old May 19, 2010 | 09:36 PM
rapticon1983's Avatar
Default 1996 accord lx...help please
I have problems with this car's a/c. When I turn my a/c on the compressor and hoses build too much pressure and that causes my a/c fan/relay fuse to blow. I was told that it might be the pressure switch or condenser. Can I please get some help???
Old May 20, 2010 | 06:53 AM
Welcome!
Could be over-charged.
Could be a plugged expansion valve.
But this section is really just for welcome & introductions. I'll move this over to General Tech where it's more likely to get good answers.
Old May 20, 2010 | 09:35 AM
deserthonda's Avatar
i have never seen or heard of higher pressure blowing a fuse,I have seen it create a leak from an o-ring ,
,i would start checking for an electrical short, start by unplugging the compressor, turn a/c on see if fuse still blows, if it still blows it is from compressor upward,, if it stop blowing could be an exposed wire or shorted a/c coil, Basically if you do not see anything obvious you need to start doing the eliminating procedure
i have seen a/c coil short out, wires pinched to ground ..
Old May 20, 2010 | 10:33 AM
Wicked Pete's Avatar
This problem is a little weird. How do the hoses build too much pressure? Has the system been recently recharged? Are you checking with AC gauges? Are they bulging?
Old May 22, 2010 | 01:57 AM
I just replaced the Compressor, Expancion valve and drier and recharged it. I had a friend of mine check for shorts but he found nothing. It build pressure when I turn the A/C on, it blows cold air for about 2 to 3 minutes then the the engine feels shaki and that when the car turn off and blows the A/C fan relay switch. And yes, it did bust the O rings from the lines connecting to the compressor. by the way how do I check the a/c coil???
Thanks for your time and reply's.
Old May 22, 2010 | 02:27 AM
The coil is the electrical part behind the pulley that has the electrical connector to the compressor. It is the part to the left of the #4 in the diagram below.
Is the coil new too?
pmb1903
Aug 3, 2014 01:21 PM
BigDaddyJay07
May 4, 2013 10:51 PM
Michael Bomes
Jan 31, 2013 02:42 PM
esan805
Mar 29, 2012 02:33 PM
mamtsberg
Mar 17, 2010 09:15 PM
