1996 accord rear disc rotors
Old Apr 3, 2009 | 08:27 AM
respectmyfresh's Avatar
Default 1996 accord rear disc rotors
im trying to replace my rear disc rotors, my question is after removing caliper and mounting bracket are the two set screws on the face of the rotor the only thing i have to remove to get them to come off or do i have to take off dust cover and spindle nut also.
Old Apr 3, 2009 | 09:53 AM
Dust cover #4 & spindle nut #40 stay behind with the hub #2. The only reason to actually remove the hub #2 is if you need to replace the wheel bearing.
The rotor #5 might be stuck on with rust, so spray some PB Blaster or Kroil or something on it. I think there are a couple threaded holes in the face of the rotor, between the lug studs. Find a couple bolts that fit (M6?) & use them as jacking-screws to push the rotor off.
Old Apr 3, 2009 | 09:56 AM
thanks alot thats all i needed to know
jrzwalker86
Dec 5, 2011 06:49 PM
Andy2k9
May 15, 2010 05:31 PM
sirgilligan
Dec 22, 2008 10:47 PM
KevinAccord
May 21, 2007 01:59 PM
marley
Mar 14, 2007 02:03 AM
