1996 Honda Accord 2.2L 4 Dr Sedan with manual transmission
Old Nov 20, 2018 | 08:23 PM
Golfmeister_b's Avatar
Default 1996 Honda Accord 2.2L 4 Dr Sedan with manual transmission
Does anybody know if the front sheet metal (fenders & hood) on a 1996 Honda Accord 2.2L and the V6 model are interchangeable? Thanks
Old Nov 20, 2018 | 08:29 PM
shipo's Avatar
While I've never tried it, I have always been told the entire front clip of the Gen 5 Accords with V6 engines is longer than an otherwise identical 4-Cylinder Accord. I've heard this often enough I believe it to be true.
A quick way to check would be to call your local bone yard and ask; they have an interchange book which will answer the question once and for all.
Old Nov 22, 2018 | 04:42 PM
The Toecutter's Avatar
I always thought the difference was between a coupe and a sedan. Not 4cyl, versus 6 cyl. Now the front subframe/engine cradle are 4 cyl/6 cylinder only.
Old Nov 22, 2018 | 05:53 PM
shipo's Avatar
Like I wrote, I have always been told, but have never verified, the two front clips were different. With that said, I just looked up the outer front fenders of the two cars:
Year -- Engine -------- Model ------- Right Front Fender --- Left Front Fender
1997 4-Cylinder Accord Sedan EX -- 60211-SV4-508ZZ -- 60261-SV4-508ZZ
1997 6-Cylinder Accord Sedan EX -- 60211-SV7-A90ZZ -- 60212-SV4-000ZZ
The above seems to indicate the two front clips are in fact different.
Old Nov 23, 2018 | 04:57 PM
Ok, it's actually the 6th gen that uses a different front clip between the coupe and sedan. My mistake.
cliff
Apr 15, 2013 02:27 PM
Gone
11
May 13, 2012 10:06 AM
75aces
Dec 15, 2010 02:46 AM
k1ngkev1n1
Jun 20, 2010 02:40 AM
peterock29
Aug 3, 2007 10:35 PM
