1996 Honda Accord 2.2L
Old Aug 14, 2011 | 08:12 PM
juice1391's Avatar
Default 1996 Honda Accord 2.2L
how are you supposed to get to the fuel filter??? its under my master cyl... but I cant get under it with all the other parts in the way anyone have a diagram? or a video would be EVEN better! Thanks guys!
Old Aug 14, 2011 | 08:54 PM
Peli's Avatar
You don't need to start a second thread for this, people will read your other thread where you've already asked this question.
Old Aug 14, 2011 | 08:55 PM
juice1391's Avatar
thanks, I didnt actually mean to post it in that one, I was trying to start a different thread since it was a different issue.. but thanks! Im just trying to figure out how this website works still
Old Aug 14, 2011 | 09:02 PM
Peli's Avatar
From this post on this website https://www.hondaaccordforum.com/for...-90-97-a-3045/
Accord 94-97 fuel filter
location, underhood, driver side, below brake master cylinder
part needed : fuel filter part # 16010-st5-933
tools needed: 10mm, 17mm sockets, 17 mm wrench, 3/8 drive short + long extension,rachet, 3/8 drive 14mm crow foot , 14mm short line wrench
this is a bit trickier to replace but it is simple..some people do the whole job from the top, that is when you will use the 14mm short line wrench,,personally i have found it a lot easier to loosen up the lower fuel line from the bottom ,,, Anyho ....
# 1 remove gas cap, to relieve fuel line pressure
# 2 raise the car up and with the long extension , 14mm crow foot , loosen the fuel line at bottom of filter DO NOT totally undo the line at this time or you will get fuel soaked,, put a pan under car so fuel can go there instead of on the floor once you totally undo the line
# 3 remove the 17mm nut at the fuel rail,( top end of fuel hose going to filter ) do not loose the aluminum washer you need to reuse it
# 3.5 remove the 17mm bolt for the fuel hose at fuel filter,remove the hose
# 4 totally undo the lower fuel line but undo it from the top ( engine compartment)
# 5 remove the 10mm fuel filter bracket bolt,, remove the assembly . you might have to play with it a bit but it will slide up by the master cylinder
# 6 once out, remove the 10mm bolt that hold the filter in the bracket., install new filter, make sure to line it up on the slot
# 7 if you look at the body where filter bracket mounts, there is an opening , below where the mounting bolt is, make sure to install the lower bracket nipple inside that hole,
# 8 before you install the 10mm bracket bolt, start the lower fuel line , from the top , make sure to turn the nut a few turn to make sure it is not cross threaded. once line is started ok, mount the bracket on the body tighten the 10mm bolt,,
# 9 tightem the lower fuel line ,,
# 10 install the upper hose, make sure to use new aluminum gaskets, put gas cap back on
Start the car and make sure there are no fuel leaks
Old Aug 14, 2011 | 09:29 PM
juice1391's Avatar
step 10 refrence, will the aluminum gasket come with the filter? or do I need to get this separate?
Old Aug 14, 2011 | 09:55 PM
Peli's Avatar
A gasket should come with it, generally parts like that do, but I've never bought one myself so I can't say for sure.
trolddk
Jul 3, 2013 06:08 PM
dswiz1984
Oct 17, 2008 09:10 PM
kingofqueenz
Aug 9, 2007 09:55 PM
marky
Mar 13, 2007 05:06 AM
accordlowered04
May 11, 2005 07:07 PM
