1996 honda accord
Old Sep 22, 2011 | 09:37 PM
chastinscott's Avatar
Default 1996 honda accord
car started sputtering while i was driving and every time i press the gas it sound like it would kill out but when i let off the gas it would still be running, so i couldn't accelerate anymore so i pulled over and it killed and it want start back up... mabey full pump or filter? help plz ty
Old Sep 22, 2011 | 11:04 PM
You need to determine if the problem is due to lack of spark of lack of fuel.
First though, are you maintenance items up to date like the distributor cap, distributor rotor, and the spark plugs?
Did the check engine light turn on while driving? If so, go to the common diy thread on top of the gen tech forum and follow the instructions in the how to check engine codes thread. Post any codes on here.
A quick test for fuel is to turn the key to to the II position, but do not try to start the car. When the check engine light turns on for the bulb check, the fuel pump should turn on for about two seconds. It is a faint whirling/buzzing sound that comes from the back seat, so turn off the radio, blower, etc.. and listen carefully.
Old Sep 23, 2011 | 11:17 PM
lol check this out on the way back pullin my car with a chain and no power steerin or breaks, i had to ride the breaks and the power break all the way to my house and the breaks went to the floor. I can pump the breaks and it will stiffin back up but if you wait a sec and press them again they will go to the floor? and advise on what might have went out?
Old Sep 24, 2011 | 12:17 AM
Check the brake fluid level. If it is ok, then you may have a problem with the brake master cylinder starting to fail.
trolddk
Jul 3, 2013 06:08 PM
dswiz1984
Oct 17, 2008 09:10 PM
kingofqueenz
Aug 9, 2007 09:55 PM
marky
Mar 13, 2007 05:06 AM
accordlowered04
May 11, 2005 07:07 PM
