1996 Honda accord LX key stuck
The key is stuck in the ignition it won't budge. Not sure why. The mechanic thinks it might be a blown fuse. Anybody else have this same problem or have a guess as to why?
I hope it's not the cylinder. >_<
Thanks,
Josh
Thanks,
Josh
it turns back and forth between to starting it, but sometimes it gets stuck before accessory mode. I figured out a fix, I just turn the wheel and it comes loose. If that doesn't work I hold the shifter button and it turns freely. My dad says it's nothing to worry about, since it moves. If it was the cylinder it probably wouldn't budge.
cchandler
Jan 23, 2013 11:27 PM
