1996 Honda Accord Stalling Problem
I'll see if I can rent/borrow a fuel pressure gauge from parts store. Do you know if the service port for this is standard or will I need some type of adapter to connect? If fuel pressure gets low when engine warms up, would that cause an abrupt stall or would it sputter out?
Haven't been able to do much more testing on this in the last week, but started it up this weekend in the driveway. It started no problem and idled in park for 10 mins until it warmed up and that's when it stalled again. When restarting it, I noticed the tachometer jumping all over the place between 0 and 1500 rpms but the engine didn't rev up or down when this occurred. Within a min or so it stalled again and then it gets harder to restart. When it is hard to start, I turned the key to on and can hear the fuel pump. I was planning to swap main relay but now I'm thinking it is spark related with the distributor/ignitor and not the main relay. After I let is sit for 5-10 minutes, it starts up again with no problem and then the pattern is fairly repeatable. Any thoughts?
The tachometer signal is generated by the ignition control module, so the tach jumping all over the place points towards a spark issue.
You'll need to verify to narrow down the culprit. The ignition control module and the coil would be my next places to test.
I think the DX has the external coil, where you should be able to use a test light. Another option is to find a u-pull-it junkyard and get a 96/97 LX/DX ignition control module and coil and save money.
We can give you some tests if you'd like to try them.
Hi zombiepigs, and all.
I didn't mean to hijack the topic but my 92 accord (4cyl, AT,215k) has the same issue right now. I have a new distributor ready but not yet to replace as not sure if it's the cause. No code was shown. The tach jumped up and down but engine did not rev up down, then died.
Ticktock
Ticktock
If you already have a distributor, I would try swapping it out to see if that fixes your problem.
I tried to get to my ignition control module to check out the connections, but the darn rotor screw wouldn't come off and I ended up stripping the screw! I'm going to try one of those screw extractor bits but if that fails I'll just break off the rotor. Nothing is ever easy!
