1996 Honda Accord V6 Speedometer quit working
Old May 9, 2011 | 05:47 PM
Driver 1's Avatar
Default 1996 Honda Accord V6 Speedometer quit working
I have a 1996 Honda Accord V6 that the speedometer recently quit working on and the cruise control hasn't worked for several years. In looking through online troubleshooting for this issues it all points to the VSS. I replaced the VSS and it didn't do anything. Any other ideas of the problem here?
Old May 9, 2011 | 07:40 PM
Is Check Engine Light on? If yes, get the code from autozone, et al.
If not, a faulty gauge panel or wiring fault is the problem.
Old May 25, 2011 | 05:22 PM
1hondaguy's Avatar
Default me too
I have this same problem with mine as well. but mines not a v6. i was able to take out the whole cluster but wasnt able to fix it.
Old May 25, 2011 | 11:33 PM
00AccordLX5spd's Avatar
Registered User
I know on the 95-97 v6 the tach gets signal from the ignition coil but that doesn't really help you. The speedo went out on mine right before I got rid of it but I never fixed it. My thoughts were that mine was the cluster itself because my cruise still worked. I had researched that if the cruise didnt work it was the vss, But you replaced your vss so I am a bit stumped here. The only thing I can think to tell you to do is pull the cluster and either send it off to a speedo repair shop or buy a used one on eBay. Non-working speedos are not an easy DIY from what I have researched in the past...
Tony1M
Nov 6, 2023 08:29 PM
Lefty
Aug 15, 2014 03:38 PM
BSims66173
Nov 9, 2012 11:52 AM
9DEX
Oct 9, 2011 08:46 PM
pfrathjr
Mar 14, 2008 03:50 PM
