1997 Accord SE 4cyl No Heat
Old Sep 6, 2011 | 05:59 PM
ryandamartini's Avatar
Default 1997 Accord SE 4cyl No Heat
When I bought the car, it was in the dead of summer and it was HOT out. So I'm guessing the "heat" that came through when I tested it was just outside air.. lol.
The air conditioner both recirculating and intake mode work fine. It will freeze your doors off. I noticed today, I turned the AC down so it was not as cold and turned it all the way to hot and no hot air was coming through. I guess it is important to say that air was blowing through so I don't think it was the blower. The air coming through was also less cold, but nowhere near hot.
I know the thing is fine on coolant. Drained it all out and replaced it all when the timing belt / waterpump / 2 valves were fixed. The temp gauge never seems to go too far over a quarter under the half way point on the temp gauge. (Do accords run this cool? Might be another issue >.<)
Thanks Guys,
If this car was not free, I think I would have blowin it up with plutonium by now. Hey, its all there and drives!
Old Sep 6, 2011 | 06:28 PM
Check that the cable to the heater control valve is attached and moving, and this might seem strange but be sure the "****" isn't broken.
Old Sep 7, 2011 | 10:50 AM
Thanks, I will check!
Old Sep 7, 2011 | 11:49 AM
If the **** is actually turning the shaft, but the cable isn't moving out at the heater hose valve....
Be aware that there's one cable going from the control panel down to the heater unit where it moves the air-mixing doors. There's a second cable from there out to the heater hose. Either one of the cables might be broken or disconnected.
They operate as push-pull cables so if something sticks, the cable might kink instead of pushing its lever.
Old Sep 8, 2011 | 09:58 AM
Thanks,
I'll see if I can locate both of them and see what is going on.
donaldo1954
Dec 31, 2014 03:07 PM
skijour
Aug 15, 2012 08:31 PM
redmurf
Jul 28, 2012 08:06 AM
Cessna172
Nov 5, 2010 01:22 PM
13loody
May 6, 2010 03:55 PM
