1997 Accord V6 Power Steering & Alternator Belt R&R
Old Apr 13, 2014 | 11:31 AM
TexomaAccord's Avatar
Default 1997 Accord V6 Power Steering & Alternator Belt R&R
I'm trying to find a video or guide about replacing the power steering belt and alternator belt on my 1997 accord v6 auto.
I've found the 4 banger one, but its totally different. There is a dog leg on the passenger side, and I'm guessing I need to remove all three belts and loosen up that dog leg and jack the motor up?
Old Apr 13, 2014 | 01:33 PM
Old Apr 13, 2014 | 03:28 PM
Yeah, saw that one already. He just loosens the belt and then put its back on. Guess I'll try my own DIY video lol --- lots of editing probably
Old Apr 13, 2014 | 03:40 PM
For the alternator belt, you would first loosen the through bolt (so that the alternator can pivot), then loosen the adjusting bolt. See attached pic.
For the power steering belt, it looks like you would first loosen the mounting bolts so the pump can move a little), then loosen the adjusting nut. There may be a protective cap you have to pull off before you see the adjusting nut and bolt.
Attached Thumbnails 1997 Accord V6 Power Steering & Alternator Belt R&R-accord-v6-alternator.jpg   1997 Accord V6 Power Steering & Alternator Belt R&R-p-s-pump-bracket-v6-461747.jpg
Old Apr 13, 2014 | 10:26 PM
With the alternator, I have to remove the belt that goes to the a/c -- No big deal.
Now the power steering belt is the one with the dog leg I was referring too.
Gotta jack up engine and take that off?
Attached Thumbnails 1997 Accord V6 Power Steering & Alternator Belt R&R-wp_002151.jpg   1997 Accord V6 Power Steering & Alternator Belt R&R-wp_002148.jpg
Old Apr 14, 2014 | 09:22 AM
That looks like engine motor mount support.
Yes, you will need to jack up on oil pan w/ a wood block support on oil pan. Just take engine load slightly and remove part, allowing jack to assume load and hold engine position for re-installation.
I checked 94-97 Accord download manual for guidance and nothing on V6. I checked a later model (98-02) shop manual for guidance on belt replacement and found nothing there either.
Old Apr 14, 2014 | 10:06 AM
Thanks for looking into it. I guess a DIY video will help out. Strange that no real information is out there about the V6 belt.
Old Apr 27, 2014 | 05:47 AM
mikek
Aug 6, 2019 07:37 AM
Imonlybonnie
Nov 18, 2013 11:48 AM
aking
Apr 4, 2011 11:19 AM
ksar
Oct 17, 2008 09:27 AM
russewy
Jan 26, 2007 11:22 AM
