1997 accord won't start
Old Dec 19, 2008 | 03:26 PM
roe999
Default 1997 accord won't start
Hi all newbie here. My 97 accord will not start,engine won't turn over. I installed new battery after leaving lights on all night and was time for a new one. The car will start if you bridge the solenoid over. It will not start with key engaged in starting position. I have checked the ignition fuse under the hood.I have a wiring diagram of the starting circuit. I think maybe the starter cut relay may be bad. Where is this located,what does it look like,does it have a part# What are your thoughts? Any and all help will greatly be appreciated....Roe
Old Dec 19, 2008 | 09:33 PM
Default RE: 1997 accord won't start
Put your model and engine type in signature line.
Ignition switch likely is failing. This is a common problem in Accords. No start signal from keyswitch is most likely reason that bridging solenoid works.
Sheri6889
Jun 17, 2015 08:19 AM
974thAccord
Apr 14, 2014 01:43 AM
tomd
Mar 9, 2013 06:35 PM
Blinkinlights
Jul 3, 2010 10:10 PM
