1997 aftermarket gauges/VSS/issues
Old May 12, 2010 | 12:53 PM
fraughton's Avatar
Default 1997 aftermarket gauges/VSS/issues
ok so I took out the gauges in my wife's 97 Accord ex 6 cyl automatic, i reheated every solder joint i could find, and now the speedo works much more often than it used to, but it will still cut out randomly. The tach/rpms are also still jumpy.
I went to the honda dealership to see if i could get a new gauge cluster, but they want over 200 for just the speedo and another 160 for the tach. they don't sell the entire cluster.
I know you can get them on like e-bay and whatnot, but I don't want to buy gauges that have been used becuase there is no guarantee of how long they will continue to work, I'd really rather install a new part.
Has anyone bought aftermarket gauges ? i don't care if they are another color or anything like that, i just want new gauges that won't cost me several hundred dollars.
Also, yesterday the speedo cut out randomly, and the check engine light came on again. (it went off after i re-heated the solder joints on the back of the speedo.) I'm sure that if i take it to get an obd2 test it will read that the VSS is bad, (that's what it read the day i reheated the solder joints) I might just get the vss (like 90 bucks at auto zone) but was wondering if anyone else's accord's check engine light came on when the gauges started having issues?
Thanks for any help or experiences with the aftermarket gauges.
Old May 12, 2010 | 01:41 PM
If you are getting a code for the VSS, then you will need to diagnose the problem with the VSS. A faulty speedometer will not cause the check engine light to turn on.
Old May 12, 2010 | 03:10 PM
I also read your other post in the speedometer problems thread.
The signal for the tachometer is generated by the coil, so it may not be the tachometer that is causing it to act strangely.
tampabayshore
Nov 10, 2023 12:39 PM
vicious1025
Mar 20, 2012 05:06 PM
tlq111379
Aug 23, 2010 06:18 PM
03AccordEXBoston
Apr 7, 2008 09:48 PM
comptoncarl
Feb 8, 2007 03:04 PM
